I just did my first oil change at 420 miles. Some thoughts...
The filter was WAY too hard to get off.
The oil was MUCH dirtier than I expected.
Anyone else run into these problems? The filter would be much easier to access if you could take off the plastic panel under the engine. But, that is too much work for a simple oil change. Also, the hole in this panel is too small and not centered on the filter. So, when you take off the drain plug for the filter, it just spills onto the panel. I'm thinking of cutting a larger hole in the panel.
Was anyone surprised at how dirty their oil was? I was afraid I was too early at 420 miles, but the oil was BLACK! I could not find any metal bits in the drain pan, but it really surprised me how dirty the oil was.
Also, what brand of oil do you use? I could only find Valvoline in 5W-20. What a strange viscosity...
Just wondering if anyone else ran into these problems and what you did about it. Will let you know how my 1000 mile change goes.
