First time poster as well as first time Mazda owner here. Just bought a brand new CX-5 GT Machine Gray Metallic (3 weeks old).
I'm looking into a PPF shield for the entire front end as well as a ceramic coating.
Looking to you guys for advice, is this warranted for the MGM paint? I've read that the red paint is thin (or most of Mazdas' paint for that matter).
I can get the full front PPF (hood, bumper, fenders) and 2 layers of the ceramic nano coating for $2200 USD and wondering if all of this is necessary and/or needed?
She's the first new car I've ever owned and I want to take care of her as best I can.
It appears that you posed the same question you did in 2/2018---How did that work out --?
 A suggestion --- save $ 2186.43-  and drop $13.57 on  Hybrid- Turtle Wax brand Ceramic spray- a few rags - and go wild - Since your 5 is new - ---some experts say it takes months for the FACTORY clear coat chemicals to fully cure on to the paint and best left alone -to create a durable carapace -- Possibly just drive it for a while before doing anything extreme-
Remember that there are multiple layers of CLEARCOAT applied over the paint - ( some manufacturers obviously do a superior job over others- and use higher quality products )
 It is last line of defense against , Sun Damage , Bird Droppings , Rock Chips, Road Salts , Tar, Other drivers etc.  -- regardless -- Any aftermarket protectant gets applied to the pore less clear coat - not the paint .
 Clear Coat is already protecting the paint -- -- It often can be improved upon depending on your circumstance and the vehicle-  are you living in the Mojave desert with no garage ? Are you living somewhere that has freeze winters and they apply salt to the roads --- you get it -
If you have deep pockets -- there are custom paint shops that usually deal with vehicles that start at 6 figures and they will wet sand down the factory clear - and reapply products that are substantially superior to the existing economy grade clearcoat.
 - -   In concurrence with others here -- I am ...... far more concerned about ignorant drivers who are happy to swing their door open at full tilt to put a nice dent into the door of a new Sig Machine Grey CX5 -- This can be devastating as it breaks up a smooth and finished union of the clearcoat , the paint , the primer and the steel .- on an atomic level --  Also the front bumper and leading edge of the vehicle take quite a bit of abuse -- and the side mirrors  , just from daily driving - Iam more concerned about those areas -  Clear adhesive products which go on like decals -- have proved to protect well -- but they can fade and yellow and peel with time -
