mhanson107
Hey guys,
I haven't posted in a while, so I'm not sure if I am posting in the right place, but I will jump right into it.
I have an '04 Mazda 6 3.0L with about 160xxx kms.
A few weeks ago I got two CEL codes both of them were P2228 which from a quick search online have something to do with the barometric pressure sensor. At the same time the codes showed up both my traction control lights came on and stayed on. If I erase the codes the RPM's jump up for a second and then drop right away and the codes come back as well as the traction control lights. While I am driving if I hit a bump the traction control lights go away and it almost feels like their is a power cut and my car seems to hesitate for a second until the traction control lights turn back on.
Here is a list of what I have tried to do to fix it (none of it has fixed my problem):
replaced the barometric pressure sensor
cleaned the EGR
cleaned the throttle bottle
cleaned the filter on the cold air intake
cleaned the MAF sensor in the cold air intake
unhooked the battery for a while to try and reset it
Cleaning everything has definitely helped the car run better, but I still have the P2228 codes and the traction control lights are still on (which also means I don't have traction control- I think).
Any insight would be greatly appreciated. If you have any other questions that might help solve my problem please don't hesitate to ask.
cleaned the EGR
