CEL P0140 help
Hughes412 said:
Just to let you know. I washed down the engine bay and when I turned it on the engine light came on. Had the code checked and sure enough, o2 sensor. The second sensor was not reading. I put some eletric lube down inside the conectors and reset the ecu. That worked, light out. You might try that first, it only cost 69 cents.
bump from the semi dead....
just to get this right you put the lub in the grey connection part (where the male and female came together?)
thanks!
lube always goes where the male and female come together, you should know that
thanks!
Yep, I unplugged the O2 sensor and put the lube in the female end.
LMAO, I just realized what I just said. But anyways that fixed it.
Dirty boy!
bulb grease says it protects all electrical connections bulbs or not...
oh well...try one...if it does not work then try the other
