Hello,
Installed my Autotech HPFP internals today, and all went well except for re installing the pump itself. I feel ridiculous for not being able to re install it after I took it apart. The 3 external torx went in fine, but I cannot seem to get the feed line to the bottom of the pump to seat properly. Ive tried tightening that first then torquing the torx one by one, slowly and carefully. When I turn the ignition on to prime the pump fuel shoots out from just below the nut that fastens the pump to the line. It is not cross threaded (as far as I know) just wondering if anyone else had run into a similiar issue. Any help is appreciated. I can post pics if needed. Thanks
