car wont start with battery removed!!
yeppp some thing happen to me, it ending being a bad battery and some old corroded positive and negative wires. so i replaced them all and seems to work fine.....
also i cant remember if the same thing happens when the main fuses under the hood blows...so you might to check that out too
i'm gonna get the wires right at the end if i have the dime left. ...i wondered about fuses too but they looked ok visually
Pour some Coke* on the corrosion or use some baking soda & water. Rinse off the post and wires and then put some protectant on the post and wires. Can use petroleum jelly, silicone grease or a battery spray protectant. That will save your last dime unless the cables are shot.
