MeAndMyPenguin
- 2002.5 Mazdaspeed Protege5
Took the head off as I had a blown head gasket, sent it the machine shop to get cleaned and resurfaced. Changed the gasket and bolted it back together in the correct order at the right torque setting. I believe the timing is correctly done as the marks on the cam gears line up and the motor is at TDC. After installing everything on my P5, it was time to start it. Cranked it and no start. Cranked it again for about 30 seconds and had the pedal all the way pressed and it finally turned on but would not go past 3k rpms. When I let the gas pedal go the motor turns off. There is also this loud tapping sound coming from the head. Took off the valve cover and rechecked the timing and everything seems to be lined up but I'm not really sure. I have the MSP ecu and the ssafc installed. Any help is really appreciated as I would love to have my car back again.
