Car Help
firefox_mp
2004 Mazda 3
I own a 04 Mazda 3 4dr. just got a bit of money, and this is what im thinking of doing. Want to get the Tein SS suspension with the EDFC, and the Progressive Technology rear sway bar. It replaces the stock one with a 22mm sway bar. Also want to get the Enkei 0R52 17" rims, which im still looking at, due to the fact that I not sure if the bolt patter will match. Was just wondering tho, and from what ive read, its good things. But does anyone have the Tein SS installed on their car, if so, do you have to adjust the rear camber, and hows the ride? same for the sway bar, how does that affect the driving and all. Thanks for the help.
Can't help you with the Teins but I will tell you that the camber is non-adjustable.
Also, if you're going to go with the OR52 wheels, you had better stick to stock size because of the difference in offset. If you go with a wider wheel or a bigger tire, you're going to be rubbing the fenders.
