Car died halp!
MadOnion
Mazda Protege5
Hey guys the P5 died on me today, my wife left the lights on for about 20 mins and i had to get a boost when I got back to the car. I thought well it just went down enough to need a jump, and drove off but the radio started to turn off and the air bag light started to come on and flicker so I had to keep the revs up to keep everything on. Now I have noticed a whine for a few days thought it might be the trans something unrelated but now I think it might be the alt.. the light on the dash didn't come on at all though, do you guys think it would be the battery its self or the alt and bat? Halp I got to go back to work on boxing day.
Does the battery light come on when you first turn the key on (engine off)?
Bring it to a parts store and have the battery and alternator tested either way.
Yes the light comes on when you are in acc before you start the car but leaves once it fires up
Check the voltage at the battery with the car off. It should be about 12 volts. Then start the car and check the volts again... It should jump to 13 or 14 volts.
The battery light doesn't necessarily come on to indicate an alternator failure depending on how it fails.
An easy old school trick is to disconnect the negative battery cable with the car running.
If the car keeps running the alternator is good... If the car stalls the alternator is bad.
Some people say never to do this.. You can blow stuff up but I have done it at least three times on my P5 with no problems.
The dead battery may have been the last straw for the alternator and pooched it or your working alternator is struggling to charge a cooked battery as well as run the rest of your car.
If you can still start the car it generally means you've got a good battery with enough power to run the starter motor.
The car needs a jump to start but will stay running if the rpm are up but the alt is whining hard
Going to grab a new battery maybe it will help if the whine keeps up I'll have to get a new alt as well :(
I am hoping the bat just slowly died or wasn't charging right and finally kicked it. Consittering if I kept the rpm up evrey thing was okay .. Here's wishing
Sent from my HTC One_M8 using Tapatalk
Do not remove the battery cable from the battery while the car is running. You will burn out the diodes in the alternator. Take the battery to any auto parts store and ask them to charge it and then load-test it. If the battery is bad, then get a new one. If not, have them test the alt. I wouldnt but batteries or alts just to see if these solve the problem, as they usually cannot be returned (electrical)
Idk about Canada, but Autozone and Advance Auto in the US can test your battery, starter, and alternator for free in about 30 minutes by measuring electrical load.
This. I would never remove the negative batt cable on any modern car. That is a really good way to burn up some electronics. It was a good method back in the day when cars didn't have any electronics. Also, don't just be a parts replacer...diagnose then repair.
Too late already did it and the car died immediately, just going to replace the alt tomorrow or buy a new car maybe both well see lol
Also the batty was dead too so I think they went to the grave together
From your last post it does sound like the alternator is bad. It's very simple to measure the voltage with the car running and not. I would never replace an alternator or battery without doing this. If you don't have a multimeter, go buy a cheap one from a discount store. Or I believe Autozone will also check this for you. Autozone will definitely bench test both parts out of the car.
The alternator isn't terribly difficult to replace, but it is a pain in the butt. I wouldn't do it unless I was sure it needed it.
I believe it needs to be done now, its also whining so baddly if its not dead now it will be soon. I am not looking forward to doing the alt because of all the trouble I had with the belts and its -12 today -_-
The alternator is a pain to replace because it can be completely removed from the engine but is trapped in the engine bay.
You can remove it from the top by removing a bunch of parts or remove it from the bottom by removing the axle.
One mechanic discovered through trial and error that you can remove the joint shaft bolts and pull the axle from the transmission about a quarter of an inch. This allows the axle to wobble a bit out of the way and give just enough room to squeeze the alternator past it.
This allows you to remove the alternator from the engine bay without removing all kinds of parts... it doesn't drip any transmission oil and you don't risk damaging the oil seal on the transmission.
The alternator on our car is a bit weird and different in that it has a control wire that runs directly to the ECU and the ECU controls the output of the alternator. If that wire is broken or has a bad connection the alternator effectively shuts off.
Some people have installed 3 altenators before finding one that works. The rebuilds can have problems.
Yes, it is a pain to actually get the thing out after detaching it. I hit it from the top with a long bar until it fell out. I did not remove anything extra. I don't recall too much issue getting it back in.
I replaced to alt through the top and needless to say it was a b**** but I just moved the cruise and charcoal canister. It was still a dick to get out and then back in but I did it in about two hours.. Here's hoping it was a good alt it was bench treated before I bought it and it had 3 year replacement ******* 300 bucks later we'll see if it all worked out tomorrow
Got the alt in and it seems to be charging and running okay but now when you stop the rmp goes down to like 100 when you put the clutch in until you stop at the light then I comes back up but only once you stop moving its really strange
Don't worry about it...
Your ECU is relearning how to operate your car.
Takes about 100 miles...
