Can't remove rear reflector...
I've been trying to remove the rear reflector on my speed for the past 30 minutes... The sliding to the rear trick did not work. I also tried going from under the bumper and pushing on the clip and got no where. Am I missing something here???
Are you trying to remove the red rear reflectors in the black valence? If so... the bumper needs to be removed first.
If you are just trying to remove the reflectors on the side of the rear bumper, that can be done without removing the bumper. Stick your head under the bumper and use a flathead screw-driver to push the clip out.
Any of the online dealers would be able to sell you one. There's one I order from that's the cheapest I found. Can't post it though. PM if interested.
