F flowfish Member : 2003 Protege5 May 12, 2012 #1 I recently bought this 99 Miata, the previous owner has it really low and I'd like to raise it a bit, can you help me figure out how to raise the ride height on this specific set of coilovers? Thanks in advance.
C chiefmg MOTM July 2015 : '81 RX-7 GS, '00 Miata SE, '16 Camaro (wife's), '15 CX-5 GT AWD May 18, 2012 #2 You adjust the blue nuts at the bottom of the springs upward (compressing the spring more). This will raise your ride height.
N njaremka Wiggity-Wack-O-Tack Contributor : 2019 Mini F60 JCW May 18, 2012 #3 those look like the FM VMaxx coil overs: http://www.flyinmiata.com/index.php?deptid=4537&parentid=0&stocknumber=13-16210%20%201990-97%20NB here are the installation instructions: http://www.flyinmiata.com/support/instructions/suspension/vmaxx.pdf
