can u remove scratches from faux cf?
therizzzo
Has anyone had any luck removing the scratches from the carbon fauxber center trim ring? I got a few light but noticable scratches on mine while attempting a HU removal using those useless coat hanger tools(BTW, Mazda of Kingwood removed the HU for free).
I was thinking maybe if I used some extremely fine sandpaper or some kind of clay and then buffed the spot with a super soft wheel, that would work. Any thoughts or suggestions?
bummmmp.
anyone other ideas for my little problem? I need some options
.......bueller..........bueller...................bueller
I detail cars for a living and own an MP3. What I would suggest is cutting down and building up. What youy would do is take a real light rubbing compound and lightly rub at the scratches until the whole area is covered. Then take a wax, preferebly carnuba or something that is designed to take out swirls and apply a very small amount. Do this over until your desired effect is reached.
Would this rub off the CF finish? I mean, I wouldn't want to have an ugly spot where I got the scratches out. Is the faux CF finish just on the top of the plastic trim? I'm totally clueless about CF real or fake.
either real or fake it should have a clearcoat type layer on it which hopefully is where the scratches are and not deeper.
If thats the case the above recomendation should work fine without affecting the C/F.
If there is no clear coat it is a risk.
Im sure places have scratch fillers, so you can just fill em in with a compound that u rub in but I dont know what brands or types to trust.
thanks. I'll check with the local rice and hotrod network for some brands and types.
