Good info. I'm definitely no oil expert, but I've read a couple oil threads and what not, and am still trying to learn.
It is my understanding that the manufacturers these days are recommending the lower operating temp viscosities (20, etc.) in order to get the best mpg out of the motors. It's also my understanding (correct me if I'm wrong), that it is ok, if not better, to run a slightly higher operating temp viscosity (30, 40) in those same motors? If anything, you may lose a fraction of the mpg that the manufacturer claims (because they used 20 when testing), but get a little better protection? In all of my cursory research, you will not damage a motor that calls for (recommends) 0w-20 or 5w-20, if you use 0w-30 or 0w-40...I think? I'm still not sure of the significance of the 0w vs. 5w. I think it is the viscosity of the oil when it is cold, but I'm not sure if it has any significance, especially living in the warm state of FL. (my other vehicle "recommends" 0w-20 or 5w-20, so I figure the significance of the first number is minimal, if anything at all). At any rate, I'm going to be running the synthetic Castrol 0w-30, which is supposedly a thick 30, almost 40, and be tracking my MPG's over the next several months/year, and get the oil analyzed to see what is going on with the oil and the motor. If I'm satisfied, I'll keep running it.
