I've read some threads about needing to shim or buy new shims on new camshaft installs and i've read some that say its basically plug n play...just dropping in the new one and its done. Do I need to have it shimmed?
jspec intake and corkport exhaust
That's what most people will doShould be same base cricle as stock. See the online manual for specs and measurement instructions for valve clearance, if you don't have the manual I'll send you a link,let me know.If some shims are too tight and others too loose you can swap them with each other.
Should they spin freely? How would I know if their too tight?
Well I've already done the install and didnt measure up anything. Car idles and runs just fine. Once installed, the cams were pretty hard to rotate when trying to line up the timing marks
Where can I buy the feeler gauges? Walmart? Autozone?
