camshaft help needed asap
birdy85
Yellow Mazda SP20
i need help on camshafts quickly. Can i just buy a j-spec intake camshaft(the one one from corksport and install on its own or do you have to have both. Do you know what the set comes with do i need any extra parts etc
bird - the aussie SP20 comes with j-spec intake cam as standard.
with our higher standard compression you'll be better off getting custom cams like what i did
i bought blanks from america and had them ground at ivan tighe.
they are quite a bit more than stock...here's the basic specs :
lift intake and exhaust : 0.3512"
duration @ 0.050 - 225.9deg
duration @ 0.010 - 272.5deg
i should add, that's why i didnt get much of an increase over my previous dyno pull - they need to be adjusted and tuned
