Paul said:jdm cams. and phil i think mam is a whole short block. but let's not go that route just yet. do u think it bent a valve? or maybe the timing was just off?
wicked said:short blocks don't include heads.
but if you did bend valves then I recamend if you are going for performance,you should get a P&P job done,and go 1mm oversized on the exhaust valves.
xfaradx said:Way to play for team retard.
(bang) sorry i meant the lobesYell03SpecV said:paul, do you know what overlap is?
Yell03SpecV said:why just the exhaust valves? (poke)
