the_master
- Mazda, Protege, 1.8L
Alright so about 2 weeks ago i tried to install new tire studs on the front left side of my car and i guess i did not do it right because my tire came flying off and my car dropped on the rotor. Ever since then its been riding really rough on the left side. I went to get a front end alignment and i saw that the camber was around 2.0 (i think) and you could tell something wasn't right with the front left. So i ordered a new strut to see if that was the problem. i haven't installed the strut because i decided to take it to a shop and see what they said.
The shop said nothing is bent or broken and that the front right strut is blown out, so i need 2 new front struts. They also said i need a control arm bushing, but said that i'd have to buy the whole control arm with the ball joint, since you can't just buy the bushing. Then they said i also need a lower control arm.
all totaling $1,034.72
I went on rockauto.com and found the control arm bushing for around $8.
So i asked how to adjust the camber, since thats all i really want to do and they said i need to buy a camber adjusting kit which are basically just different bolts for the strut.
So what do you all think of this?
Should i replace all these things?
Is there a way i can adjust the camber otherwise?
