i smoke too. 08.5 GT. dp/rp intake,rcv,i am going to try a catch can in -line before the pcv valve when i install my front mount that is on order. i will update after. also i noticed i only smoke if i drive the car really really hard. it doesnt smoke if i cruise around (ex. 40 mph in 5th gear). i removed the intercooler and found no signs of oil. i dont seem to be burning much oil either. my car only has 3000 miles on it. i first noticed my car smoking after i changed the oil at 2500 miles.
Why don't you take it to the dealers...? (huh)
Its a brand new car!!! It shouldn't be smoking!!!!
Have you increased your boost at all?
If you put that catch can in there...the dealer will most likely blame the smoke on that...
I have a 2007 sport edition MS3. I have TBE, FMIC/Intake, EBC, BOV, MM & recently installed a catch can. The car has roughly 36,xxx miles and I have been smoking like a chimney at idle. I can eliminate the fact of the oil blow by because I have the catch can installed. So, that leaves me left to blame the turbo seals!!! I will be taking out my turbo this week and sending it to PG to get the reworked K04. I am pretty upset of the fact that, that money was going for a clutch because I really need it bad, but now I need the turbo fixed. Hopefully I can hold off until next income tax check to get the clutch, unless some money falls into my lap to buy it sooner. Wishful thinking. Oh well....
Upside: better turbo that is efficient to make 350whp
so you the guy who call mazda usa because your turbo went bad, and you took your car to ocean mazda without putting it back to stock, even running straight pipes all the way. i recognise your car because you took off the lower grille where your fmic is. why did you call mazda usa.?
They said they were going to try to get me a new K04. Trying to invest the money on the clutch, if I was able to get the new K04.
I was not going to put my car back to stock. If I would of gone through the hassle, I would of just sold the car off better and sold off my parts.
but you contacted mazda usa first, if you wouldnt had done that they (ocean mazda) would had replaced your turbo with no hassle, anyway im upgrading my turbo and the one i got on its only 2 weeks old because it was replaced under warranty, i migth sell the turbo if you are interested.
That is cool with the upgrade and offering the good stocker to a brother. i was wondering where your car is headed for performance and which turbo you might use to get there. feel free to pm if you like, black.but you contacted mazda usa first, if you wouldnt had done that they (ocean mazda) would had replaced your turbo with no hassle, anyway im upgrading my turbo and the one i got on its only 2 weeks old because it was replaced under warranty, i migth sell the turbo if you are interested.
has any one tried header wrap after installing new down pipe .... to me sounds like heat related issue... also anyone notice glowing turbo after a hard run or two
