Mr.Ames said:so my car's gone through 4L of oil since my last oil change. there's 115,000km on my car and ever since i had the stealership change the timing belt at 100,00km i've had crappy gas mileage and the car's been burning more and more oil. any ideas why?
Mr.Ames said:dont be a tool, of course i troubleshooted. even tried the seaform treated. nothin
pasadena_commut said:You didn't tell us what has been checked. That oil has to be going somewhere. Let's have the complete list of what you've done so far, starting with:
1. Checked for external leaks? (Especially around the drain plug and new oil filter, since you say this happened since the last oil change. Also after the car has warmed up let the car sit in one place for a while, idling and gunning the motor every once and a while, then look under it, just in case it only leaks when hot and running, that is, normally only on the road.)
2. Checked for oil in the radiator fluid?
3. Compression check?
StealthWyvern said:just for s**** and giggles check your oil presure sendign unit above the oil filer. My car was going though oil like that tell I figured out what was going on.
Mr.Ames said:how do i know if it isnt working properly?
def might be bad rings. do that compression test, it should hold pressure if the rings are fine. if you lose pressure your having blowby on that cylinder wall hence meaning you have bad rings in that cylinder.Mr.Ames said:I asked them about it and they said if the timing was off it wouldn't idle properly. Told them to check it anyway and they said ok but if i'm wrong they'll charge me for a new gasket and the labor to check it (shop rate here is $110/hour). I went and bought a compression tester so if that doesn't find the problem I'm gonna take off the valve cover and have a look myself. I have to repaint it anyway...
urbanbiker said:that idle comment is bulls***, you won't notice a bad idle if you are only a tooth or 2 off. I ran my old honda 180 degrees off. It idled fine but was completely gutless for power.
I hope they/you can figure it out and it is something simple
Matt
