Built in antenna
bhammer
I think I posted this in the wrong spot the first time around...
I need to hook up a FM modulator for my XM radio I have. It has a clip that is supposed to clip on to the antenna. Where is the built in antenna?
Thanks, Is it part of the heater element that runs through the window? I see the wire that clips onto the the heater element, is that the antenna?
The upper portion (smaller grid) is the antenna. The lower (bigger grid) is for heating the window.
I would guess there is probably an antenna connection point closer to the front of the car, probably in the driver's foot well near the fuse box.
