Nice work ,glad you got it out without taking the manifold offLinuxRacr said:VICTORY IS MINE!!!
macklum said:These are also called helicoils ,they are used when you need to keep the same threas and size of bolt or stud
I stand corrected ,these do look better than helicoilsLinuxRacr said:These are actually different from helicoils, as they are not helicoils, but a solid insert.
+2dominoy2k1 said:anyone know what set is needed for the valve cover bolts?
Luckily, the bolt that snapped was the bottom, center one, and I was just able to get my reversable air drill in there, and then I replaced it with an A2 Stainless Steel Stud, and lock nut I had.bazooka joe said:how did you get the drill in there?
LinuxRacr said:Luckily, the bolt that snapped was the bottom, center one, and I was just able to get my reversable air drill in there, and then I replaced it with an A2 Stainless Steel Stud, and lock nut I had.
