Mazdaspeed2oo35
600whp - 600wtq at 30 PSI
I got ya...
I'm running Nitto NT555 extremes 225/35/18 which may be slightly less grippy dry than the BFG KDW-2s I had before. Both are great in wet.
Nice Didn't know they make 35 profile for 225's..
I got ya...
Actually with straight cut gears the axial forces are pretty much eliminated. This is what causes case flex.
When the stock helical gears are under extreme forces they try to push each axially away from each other. I would think the bearing cup reinforcement would possibly be helpfull even with the stock gearset
What did u do to improve on the reinforcement cups?I had gone through 4 3rd gears, including a gtx 3rd, and 2 4th gears. Frustrated, i ordered the Par straight cut 3rd and the reinforcement cups. I was disapointed in the cup design so we improved upon it an installed it.
4 months 10,000 miles on broken pavement, and 280lbft of torque, its still good.
When i inspected the housing during the build it was worn around the mainbearing support area... Hence premature failure even at 230lbft (last failure occured at 9psi).
Crunchy is definitely a better word for it than clattering, and it's definitely louder at lower RPMs in lower gears. But going through a tunnel for example, cruising in 4th gear at 2500 rpms, the crunching/churning sound is quite pronounced even over my exhaust.
I had the work done at a shop I've been going to for a long time and trust him a lot -- he's built several G series transmissions before, and I gave him all the specifications to use and am sure they're correct, assuming he did it right.
I've driven it about 1000 miles with the new gearset and it doesn't seem to be getting worse or anything, gas mileage is the same and the car is ridiculously quick with the new closer ratio and shorter final drive... just don't want to have to drop the transmission again for a long time since this was the second time in the last 6 months.
I should also note that I think these are the older style PAR gears and they were expected to be really loud.
Yes it stops with the clutch in, and it does make some noise at idle with the clutch out but not as much as at low RPM in gear.
