Brass Bush
TieNN89
Mazda MX-5 NB8A 1998
And so I decided to change the oil in the shift turret
When I took the shifter out and took the brass bush out this is what it looks like now
normal?
its from my NB8A 5 Speed which has an IL Motorsport Quick Shift Kit fitted to it
huh... I thought that bushing was some sort of plastic / nylon.
I've never seen one of those bushings before; but, based on what I've seen before in bushings, that one doesn't look good. The irregular edge tells me there has been some excessive wear in that area. One might want to consider replacing it, at some point in the near future. Of course, I could be wrong.
i dont know its meant to be better than the plastic one which is why i replaced mine
but some say my quick shifter might not be installed properly resulting to that
well the top edges are thin and sharp now
it wasn't like that before was at least a few mm thick
