tweakingmsp
- 2003.5 MazdaSPEED Protege
I'm having some issues with my brakes. First off, my left rear caliper is starting to seize up a little. When the car is jacked up, I can barely spin the wheel when the e-brake is off. Now my left front caliper is starting to act up, it is rubbing real bad, and starting to squeal. It gets pretty hot after like a 5 mile drive. Is there something that would cause my left side to seize up?
Also, my e-brake is only working on the left side. The right side spins freely when the e-brake is on. And the left side grips, but not that much. What do you guys think the problem is? E-brake cables?
