brake light in cluster?
lowkota92
2002 mazda protege 5
my brake light in my cluster keeps turning on every other week. i found its because the brake fluid keeps dropping very little amounts. ive already done new brakes and rotors all around bled the whole system of coarse checked for leaks at all lines calipers and the master can not see where its going. i know when your pads wear it cause calipers to push out more taken more fluid but in this case thats not where its goin ive pushes the calipers back and fluid does not return. anyone got any ideas or sugestions
Park on some clean cardboard to see if there is a leak and where it is. If you don't find anything the master cylinder could be leaking into the brake booster. Do you hear a sloshing/sucking/gurgling when you press the brake?
Bang on reasoning, I had an Accord with a mystery brake fluid leak, Master cylinder was leaking into the booster.
Pat.
i tried the cardboard already... inspected all lines, separated masterfrom booster no fluid found. its gotta be leaking from somewhere just dont know where
