(hand) I just installed it yesterday. Does any one have one and can give me advice. They recommend running a ground to the battery, but said it would be okay to ground to the chassis. I am using 4 gauge power and grounds for the batcap and 8 gauge from the amps (less than 2 feet of power wire). I am running a JBL BP600.1 Class D amp and a SoundStream Class A6.0 (roughly 50 watts RMS per channel in to 12 volts and 150 in to 14.4 volts) for my mids and highs. Dimming is still the same with or without the batcap.
FYI, I installed it, ran the car for 20 minutes, drove with the radio off for about 30 minutes, and then turned the HU on, but had the volume at 0 in hopes of charging it properly. Then last night, I took it for a test run and dimming still persists. (poke) WTF? Any suggestions?(help)
I have never had so many problems as with my Pro than any other car.(blackpro) (uhm)
