I'm pretty sure running 8-9psi is just fine. I haven't done it yet, only because I can't afford a controller right now. Some things to invest in when raising the boost. Gauges: Boost gauge for sure(oil psi, and A/f also would be a good idea), colder plugs, run as high octane as possible. And when you get a boost controller, try to find one that really prevents spiking in the boost. I'd go Elecetric Boost Controller over Manual, cause if your running, and notice spiking you can just lower the boost from inside the cabin, and not worry about pulling over to lower the boost. I personally wouldn't run higher than 8.5 to 9 psi of boost wothout investing in Forged interanls, engine managment of some kind, FMIC, Fuel Delivery upgrades, and alot of wishful thinking. It is safe to run 8-9psi, if you know what your doing. Take your time, don't rush into it. Do research. I've done this. I know waiting helps, as when I first moved into the turbo world, I thought it would be ok to just up the boost to 15psi with no major upgrades. If I said, or even thought that know, I'd kick myself in the head. Point is, know what your doing before you raise the boost. Also, when boosting higher than stock, consider the load in your car. Don;t go boosting 9psi with 4 adults, and a trunk load of stuff, it puts more stress on the engine, you don't need that.
