Boost targets correct for my cobb modded car?
18psiWhiteMS3
Banned
2009 MazdaSpeed3
Ok guys mods are in my sig, my a/f at wot is 11.5-12.0. showing 0 knock. fuel pressure is between 1700 and 1900 at redline. i did a few 3rd and 4th gear pulls from about 3-4000 rpm. My boost spikes up to 20 then slowly starts to work its way to to between 17-18 at redline. 3rd gear redline is usually in 17psi range and 4th is 18pi range at redline. spiks are consistantly 20. car runs great but just wanted to see if thats whats expected. the map is the v103 FMIC map.
Yah Actually sounds about rite. U shudnt spike no higher then 20-22 psi. Anything more then that cud be a problems for ur turbo in the feature. where your car is, is about where i want mine to be as far as tuning. Nice car bro keep it clean (wrc)
Yeah man if you are with 0 knock and running those then ya you are running well. The Stage 1 maps with 93octane are set to go for 18.5psi with spikes of 20psi. 91 is a little less but if you aren't spiking any higher than 20 then you are all set.
What your seeing checks out against the notes for that tune. Would love to see a dyno of your setup.
