thanks manCustomMSP said:Tomorrow I will its 12:30am here and cold as Alaska outside![]()
CustomMSP said:I found that if I used the fuel pressure regulator line the niddle in the gauge fluctuated at very lite throttle pressure. If I used the line that connects to the top of the intake manifold close to the throttle body it worked fine.
deckedoutmp5 said:here is mine. holds my solenoid too.
