Boost Gauge
Wes said:
Nah, ordered it directly through ProSport... I think since yours is the one with the warning light and all that, you may have gotten more for your money. Who knows. Eh, my cup is real CF though (ugh)
Yeah only the new "pro" line that just came out comes with the cup. I have 4 prosport gauges (egt, oil temp, oil pressure, and boost, all electronic) and none of them came with it.
It has been accurate and reliable for me so far (used them for 2 months now. The amber/white models can actually display red too if you don't hook up the white or orange wires. I know the amber is red enough to match the MS6 interior lighting pretty much dead on, but on my Protege the lighting is more red so the red is a much closer match.
Sweet thanks for the posts. Once I get my new Speed I will have to get one. Anyone else with the prosport gauge?
Okidoki, does anyone know where or if there is any A-pillar pods yet availiable for the ms3?
Not sure this should be posted here. But my question is about the type of boost gauge to buy. Mechanical or electrical? Which one provides results with less needle fluctuation or bounce? Will installing a boost gauge void warranty?
Boost gauge will not void any warranties, due to the fact that you are only observing vacuum you are not changing anything. Plus the dealer will have to prove that your gauge caused a part to go bad. In which case will never happen unless you dont have a clue how to install.
Mechanical is the best way to go, simply cause you know what the motor is reading in real time. The electronic has to do a self check everytime(in most cases) and may not be exact in its calabration. With a mechanical you will know if it is out of calibration real fast (engine off should be reading 0). I think it is a matter of opinion and preference on which one to go with.
how do you install that?
i just put a cia on my speed3 its awsome sounds like a big whip cream can under my hood(turbo), I want to get a boost gage i was wondering how to install it?
What the hell does a whip cream can sound like? Did I miss something in my college years?
(uhm)
All I know is...when you do tons of "Whip Its" everything sounds like Whip Cream!!!!
I just got the prosport gauges, boost, oil pressure and volt 4 now. Much nicer than the motions of mechanical gauges. Color match is the best I have seen.. Boost reading are 14-15.5 in upper gear up from the 12-13 I usually saw from my stewart warner gauges. I checked the stewart warner with my air compresser and they were accurate with a steady pressure. I not sure why these are higher?They have peak hold and warning so thats pretty sweet to. I see peaks of about 18 in 5-6th gears. Anyone else have them. I notice the start up ceramony is the same with the boost and volt but the oil lags behind .25 seconds??? 18psi oil pressure at hot idle and 90psi cold at 3.5k or so.. I have had a few sets of mechanical and will say, I will never buy mechanical again....These work much quieter,smoother,and look to be more accurate with reading others are getting...(boom07) (gun)
what are you guys tapping off of with the mechanical gauges? Can you just T off something?
oh, how do the electrical boost gauges get their reading?
zoom-zoomhatch said:
I think they have them at ********** but won't those cause problems with the side curtain airbags?
I wouldnt place a pillar over the side air bags, if they go off that thing will probably fly right in your face.
Just get one of these:
how do you install the electrical wireing on the boost guage?
Vermilion said:
These 2 pics are Desperado-C's install. Mine looks almost identical though.
i have a speed3 bought a boost guage, how do i installl the elctric wireing do i have to pull the dash?, reaaly apprieciate any help
you know i big loud whooooooooosh sound , turbo spooling up
(uhm)
a big loud whoossh sound(drive)
