BMW 335i M Sport Touring 300hp
mikeyb
Contributor
01 BMW 325xi Touring
[FONT=Arial, sans-serif]New pinnacle for 3 Series Touring[/FONT]
[FONT=Arial, sans-serif]The BMW 335i Touring represents a new pinnacle for the 3 Series Touring range. Never before has BMW produced such a powerful, yet economical, compact estate car capable of carrying five adults and all their luggage. Its introduction into the 3 Series Touring range at the same time as a twin-turbo diesel powered model completes a line-up that stretches from 2.0-litre petrol and diesel entry-level cars all the way to the two twin-turbocharged flagship variants offering the widest range of possible choice for the customer.[/FONT]
[FONT=Arial, sans-serif]Drivetrain[/FONT]
[FONT=Arial, sans-serif]Powered by a twin-turbocharged 3.0-litre engine developing 306hp, the 335i Touring is the fastest-ever 3 Series estate BMW has produced. It accelerates from zero to 62mph in 5.7 seconds before going on to an electronically-limited top speed of 155mph. Such rapid progress is made possible thanks to two turbochargers each supplying compressed air to three cylinders in the straight-six cylinder 2,979cc engine.[/FONT]
[FONT=Arial, sans-serif]Unlike some competitor powerplants that use a single large turbocharger to power a petrol engine, the 335i Touring uses two smaller units to ensure a faster reaction to throttle inputs. Because they ‘spool’ up more quickly, the affects of turbo lag are negated. The instant performance of the straight-six cylinder engine means the car is capable of swift in-gear acceleration with 400Nm of torque available from 1,300 to 5,000rpm making for effortless, smooth driving.[/FONT]
[FONT=Arial, sans-serif]Aiding the 335i Touring’s performance, but also benefiting economy, is BMW’s all-new High-Precision Direct Injection system. Piezo injectors are centrally located in the combustion chamber between the inlet and exhaust valves to deliver atomised fuel in a conical burst into the chamber. The result is a smooth, efficient burn with only the exact amount of required fuel mix being delivered into the combustion chamber on each cycle. This method of injection also serves to aid combustion chamber cooling, thus offering a higher compression ratio and improved fuel economy.[/FONT]
[FONT=Arial, sans-serif]The engine in the 335i Touring comes with BMW’s innovative Bi-VANOS system for optimum engine efficiency that further benefits performance and economy. Bi-VANOS determines when the intake and outlet valves open so that only the exact amount of fuel mixture passes into the combustion chamber. The aluminium 3.0-litre engine also uses an electrically-powered water pump that, without the power drained from a conventional crankshaft driven unit, is 90 per cent more efficient than a mechanical pump, further aiding economy. [/FONT]
[FONT=Arial, sans-serif]Power in the 335i Touring is transferred to the rear wheels via a six-speed manual gearbox as standard. Customers can specify an all-new six-speed automatic gearbox with steering wheel-mounted paddles for gear selection.[/FONT]
[FONT=Arial, sans-serif]Chassis[/FONT]
[FONT=Arial, sans-serif]Like all other BMW products, the new 335i Touring has near-perfect 50:50 weight distribution and comes with a front engine and rear-wheel-drive set-up to deliver an unsurpassed driving experience in its segment. It achieves this by using a double-joint tie bar aluminium front axle to deliver a rewarding combination of agile steering and good ride. At the rear, a five-link rear axle is constructed from high-grade, lightweight steel for strength but retains high levels of elastokinematic flexibility to iron out road imperfections. Many suspension components are manufactured from aluminium to reduce the car’s unsprung masses and further improve ride quality.[/FONT]
[FONT=Arial, sans-serif]The 335i Touring uses a traditional rack and pinion steering set up as standard, providing the highest levels of feedback and accuracy. Customers can opt for BMW’s innovative Active Steering system. Active Steering varies the steering ratio in relation to vehicle speed by adding driver input to assist in slow speed manoeuvres such as parking, or reducing it to contribute to high-speed stability.[/FONT]
[FONT=Arial, sans-serif]Safety[/FONT]
[FONT=Arial, sans-serif]The BMW 335i Touring comes with one of the most advanced forms of traction control system currently available in the world, Dynamic Stability Control+. In addition to the renowned benefits of previous traction systems offered by BMW, DSC+ takes things a stage further with five additional safety functions.[/FONT]
  • [FONT=Arial, sans-serif]Brake Pre-tensioning shortens stopping distances by priming the brakes if the driver instinctively lifts off the accelerator in preparation for an emergency stop.[/FONT]
  • [FONT=Arial, sans-serif]Brake Drying improves braking performance in the wet by periodically gently applying the pads to the discs. In wet weather conditions, a film of water can build up on the disc hindering stopping power but this slight braking action removes this film and ensures optimum retardation.[/FONT]
  • [FONT=Arial, sans-serif]Hill Start Assistant allows the driver of a manual transmission car to pull away smoothly on a gradient without having to balance the clutch and the throttle. Brake pressure is maintained for the time it takes to move the foot from brake to accelerator, preventing the car from rolling backwards. [/FONT]
  • [FONT=Arial, sans-serif]Fade Compensation can apply additional braking without any extra effort from the driver. Following very spirited driving the brakes may experience some fade due to excessive heat build up. However, Fade Compensation means the pads still bite the disc for optimum stopping power.[/FONT]
  • [FONT=Arial, sans-serif]Soft Stop contributes to a smoother journey for all occupants. A small proportion of braking pressure is released as the car comes to a standstill, minimising the potential for a sharp, halting stop.[/FONT]
[FONT=Arial, sans-serif]When a tow bar is fitted, BMW’s innovative Trailer Stability Control becomes part of the DSC+ system. When the yaw sensor detects any pendulum motion of a towed vehicle or trailer, DSC intervenes to reduce the throttle and brake individual wheels to bring the trailer back under control.[/FONT] [FONT=Arial, sans-serif]The optional Active Steering system has an added safety benefit as it is linked to DSC+. It can therefore detect if the car’s speed is too high for a cornering manoeuvre and, if this is the case, apply a small amount of additional counter-steer to bring the car back under control.[/FONT]
[FONT=Arial, sans-serif]Occupants in a BMW 335i Touring are protected by up to six airbags. The driver and front passenger are protected by two-stage intelligent airbags with an inflation rate dependent on the severity of the accident. Seat bolster-mounted side airbags offer further protection. Front and rear passengers are protected by a curtain airbag that inflates between the A- and C-pillar, protecting both the head and upper body from an impact and from any shards of glass or intrusions entering the cabin. [/FONT]
[FONT=Arial, sans-serif]The BMW 335i Touring features BMW’s Brake Force Display system, that illuminates an additional rear lighting segment in the event of an emergency stop, and Run-flat tyres. These allow a driver to complete their journey in the event of a puncture without having to perform a dangerous roadside wheel change. A car with a flat tyre can continue for more than 150 miles at speeds of up to 50mph.[/FONT]
[FONT=Arial, sans-serif]Design[/FONT]
[FONT=Arial, sans-serif]Available in either SE or M Sport trim, the 335i Touring is the most distinctive yet practical car among its peers. With the 60:40 split folding rear seats in place, 450 litres of space is available – the extra 15 litres making the car more spacious with its seats up than an Audi A4 or Jaguar X-Type. With the seats folded, 1,385 litres are available for larger, bulky items, topping the space available in the Mercedes Benz C-Class Estate and the Audi A4 Avant.[/FONT]
[FONT=Arial, sans-serif]Retaining familiar BMW design cues, the front view of the new 335i Touring features the classic double kidney grilles, twin headlamps, and pronounced power dome in the bonnet. In profile, BMW’s characteristic long bonnet, short overhangs and traditional ‘Hofmeister kink’ and swept-back glasshouse continue to showcase the visible BMW DNA.[/FONT]
[FONT=Arial, sans-serif]At the rear, the practical aspect of the 335i Touring is evident in its design. The new 335i Touring features a split-opening rear tailgate, enabling the rear window to be opened independently. For larger items, the height and width of the loading aperture have been maximised by a cut-out in the rear bumper that lowers the loading height. Two-piece rear lamp clusters, split between boot lid and body, increase available width. The boot lid also lifts to a height that allows anyone under two-metres tall to stand beneath. [/FONT]
[FONT=Arial, sans-serif]Market and history[/FONT]
[FONT=Arial, sans-serif]Though a turbocharged engine in a petrol-powered BMW hasn’t been seen since the 745i of the early 1980’s, BMW has an illustrious history with forced induction engines. The first production turbocharged BMW car was the highly popular and now iconic 2002 Turbo of 1973 while it was a BMW turbocharged engine with more than 1,000hp that powered Nelson Piquet to the Formula One World Championship in 1983.[/FONT]
[FONT=Arial, sans-serif]Now a turbocharged petrol engine comes to the 3 Series Touring for the first time in what is the model’s fourth incarnation. This latest generation was initially offered as a 2.0-litre diesel or a 2.5-litre-petrol engined model at its launch in September 2005, with other engine derivatives being offered later. The introduction of the 335i Touring, alongside the new twin-turbo 335d Touring, tops a range of cars that offers 10 different engine outputs, three gearbox choices and three trim options, plus a raft of technological optional equipment.[/FONT]
[FONT=Arial, sans-serif]The majority of owners are aged between 36 and 55 with over half younger than 50, while approximately 80 per cent are expected to be male. Around 17 per cent of owners are self-employed while over 60 per cent are company directors or managers. Golf, rugby and skiing are their favourite sports.[/FONT]
[/FONT]
<table width="75%" border="1" bordercolor="#000000" cellpadding="7" cellspacing="0"><colgroup><col width="124"></colgroup><tbody><tr valign="top"><td width="52%">[FONT=Arial, sans-serif]Year[/FONT]
</td><td width="48%">[FONT=Arial, sans-serif]Total 3 Series Touring sales[/FONT]
</td></tr><tr valign="top"><td width="52%">[FONT=Arial, sans-serif]2002[/FONT]
</td><td width="48%">[FONT=Arial, sans-serif]7,290[/FONT]
</td></tr><tr valign="top"><td width="52%">[FONT=Arial, sans-serif]2003[/FONT]
</td><td width="48%">[FONT=Arial, sans-serif]8,274[/FONT]
</td></tr><tr valign="top"><td width="52%">[FONT=Arial, sans-serif]2004[/FONT]
</td><td width="48%">[FONT=Arial, sans-serif]7,150[/FONT]
</td></tr><tr valign="top"><td width="52%">[FONT=Arial, sans-serif]2005[/FONT]
</td><td width="48%">[FONT=Arial, sans-serif]6,412[/FONT]
</td></tr><tr valign="top"><td width="52%">[FONT=Arial, sans-serif]2006 (end September)[/FONT]
</td><td width="48%">[FONT=Arial, sans-serif]7,202[/FONT]
</td></tr></tbody></table>
<table width="100%" border="1" bordercolor="#000000" cellpadding="7" cellspacing="0" rules="rows"><colgroup><col width="75"></colgroup><colgroup><col width="29"></colgroup><colgroup><col width="29"><col width="25"><col width="25"><col width="35"><col width="39"></colgroup><tbody><tr valign="top"><td width="29%" height="32">[FONT=Arial, sans-serif]Model[/FONT]
</td><td width="11%">[FONT=Arial, sans-serif]Price OTR[/FONT]
</td><td width="11%">[FONT=Arial, sans-serif]Power (Hp)[/FONT]
</td><td width="10%">[FONT=Arial, sans-serif]Torque (Nm)[/FONT]
</td><td width="10%">[FONT=Arial, sans-serif]Zero to 62mph[/FONT]
</td><td width="14%">[FONT=Arial, sans-serif]Combined mpg[/FONT]
</td><td width="15%">[FONT=Arial, sans-serif]Emissions (g/km)[/FONT]
</td></tr><tr valign="top"><td width="29%" height="10">[FONT=Arial, sans-serif]BMW 335i SE Touring[/FONT]
</td><td width="11%">[FONT=Arial, sans-serif]32,110[/FONT]
</td><td width="11%">[FONT=Arial, sans-serif]306[/FONT]
</td><td width="10%">[FONT=Arial, sans-serif]400[/FONT]
</td><td width="10%">[FONT=Arial, sans-serif]5.7[/FONT]
</td><td width="14%">[FONT=Arial, sans-serif]28.8[/FONT]
</td><td width="15%">[FONT=Arial, sans-serif]235[/FONT]
</td></tr><tr valign="top"><td width="29%" height="10">[FONT=Arial, sans-serif]BMW 335i M Sport Touring[/FONT]
</td><td width="11%">[FONT=Arial, sans-serif]34,920[/FONT]
[FONT=Arial, sans-serif]Standard equipment[/FONT]
[FONT=Arial, sans-serif]Engine[/FONT]
  • [FONT=Arial, sans-serif]Four valve technology[/FONT]
  • [FONT=Arial, sans-serif]Double-VANOS[/FONT]
  • [FONT=Arial, sans-serif]Twin variable turbochargers[/FONT]
  • [FONT=Arial, sans-serif]High Precision Direct Injection system[/FONT]
  • [FONT=Arial, sans-serif]3-way catalytic converter fully controlled, heated oxygen sensors [/FONT]
  • [FONT=Arial, sans-serif]EU4 emissions management[/FONT]
[FONT=Arial, sans-serif]Transmission[/FONT]
  • [FONT=Arial, sans-serif]Six-speed manual gearbox[/FONT]
[FONT=Arial, sans-serif]Wheels and chassis[/FONT]
  • [FONT=Arial, sans-serif]SE - 17-inch light alloy Star-spoke style 158 with 225/45 R17 Run-flat tyres[/FONT]
  • [FONT=Arial, sans-serif]M Sport - 18-inch light alloy M Star spoke style 193M with 225/40 R18 front and 255/35 R18 rear tyres[/FONT]
  • [FONT=Arial, sans-serif]Run-flat Tyres[/FONT]
  • [FONT=Arial, sans-serif]Double joint trailing-arm axle, front subframe and axle control arms aluminium[/FONT]
  • [FONT=Arial, sans-serif]Ventilated front and rear brake discs[/FONT]
  • [FONT=Arial, sans-serif]Anti-roll bars front and rear[/FONT]
[FONT=Arial, sans-serif]Safety and technology[/FONT]
  • [FONT=Arial, sans-serif]Airbag features:[/FONT]
    • [FONT=Arial, sans-serif]ID driver and front passenger airbags (Impact-Depending Airbag System)[/FONT]
    • [FONT=Arial, sans-serif]Side airbag for driver and front passenger[/FONT]
    • [FONT=Arial, sans-serif]Seat occupancy detector for front passenger airbag[/FONT]
    • [FONT=Arial, sans-serif]Passenger airbag deactivation for child seat use[/FONT]
  • [FONT=Arial, sans-serif]Seat belts, inertia-reel at the front with pyrotechnic belt latch tensioner, belt force limiter and belt retainer[/FONT]
  • [FONT=Arial, sans-serif]Battery terminal and alternator isolators[/FONT]
  • [FONT=Arial, sans-serif]Crash sensor[/FONT]
  • [FONT=Arial, sans-serif]Anti-lock brake system (ABS)[/FONT]
  • [FONT=Arial, sans-serif]Aluminium brake calipers, front and rear[/FONT]
  • [FONT=Arial, sans-serif]Brake Force Display[/FONT]
  • [FONT=Arial, sans-serif]Compound disc brakes, inner-vented and cross-drilled all round[/FONT]
  • [FONT=Arial, sans-serif]Corner Brake Control (CBC)[/FONT]
  • [FONT=Arial, sans-serif]Dynamic Brake Control (DBC)[/FONT]
  • [FONT=Arial, sans-serif]Automatic Stability Control + Traction (ASC+T)[/FONT]
  • [FONT=Arial, sans-serif]Dynamic Stability Control +[/FONT]
  • [FONT=Arial, sans-serif]Headlight washing system[/FONT]
  • [FONT=Arial, sans-serif]Alarm system (Thatcham Category 1)[/FONT]
  • [FONT=Arial, sans-serif]Central locking switch in centre of dashboard[/FONT]
  • [FONT=Arial, sans-serif]Central locking with electronic immobiliser and integrated fuel tank filler flap lock[/FONT]
  • [FONT=Arial, sans-serif]Check Control warning system[/FONT]
  • [FONT=Arial, sans-serif]ISOFIX child seat fixings, rear[/FONT]
  • [FONT=Arial, sans-serif]First aid kit and warning triangle[/FONT]
  • [FONT=Arial, sans-serif]Park Distance Control (PDC), rear[/FONT]
  • [FONT=Arial, sans-serif]Ergonomic belt system at the rear with three-point belts on all seats[/FONT]
  • [FONT=Arial, sans-serif]Headrests in all seats[/FONT]
  • [FONT=Arial, sans-serif]Rain sensor[/FONT]
  • [FONT=Arial, sans-serif]Remote control key with boot release (rechargeable)[/FONT]
  • [FONT=Arial, sans-serif]Tyre Puncture Warning System[/FONT]
[FONT=Arial, sans-serif]Exterior Equipment[/FONT]
  • [FONT=Arial, sans-serif]Exterior mirrors – heated with electric adjustment[/FONT]
  • [FONT=Arial, sans-serif]Clear indicator lenses[/FONT]
  • [FONT=Arial, sans-serif]Chrome kidney grille[/FONT]
  • [FONT=Arial, sans-serif]Roof rails, black[/FONT]
  • [FONT=Arial, sans-serif]Heated windscreen washer jets[/FONT]
  • [FONT=Arial, sans-serif]Chromeline exterior trim (SE only)[/FONT]
  • [FONT=Arial, sans-serif]Twin chrome plated exhaust pipes[/FONT]
[FONT=Arial, sans-serif]Interior Equipment[/FONT]
  • [FONT=Arial, sans-serif]Automatic air conditioning – advanced[/FONT]
  • [FONT=Arial, sans-serif]Air micro filters[/FONT]
  • [FONT=Arial, sans-serif]Central air outlet, rear centre console[/FONT]
  • [FONT=Arial, sans-serif]On-board computer (OBC) including:[/FONT]
    • [FONT=Arial, sans-serif]Fuel consumption[/FONT]
    • [FONT=Arial, sans-serif]Outside temperature display[/FONT]
    • [FONT=Arial, sans-serif]Speed limit function[/FONT]
  • [FONT=Arial, sans-serif]Reading lights front and rear[/FONT]
  • [FONT=Arial, sans-serif]Extended interior light system[/FONT]
  • [FONT=Arial, sans-serif]Automatic interior dimming rear-view mirror[/FONT]
  • [FONT=Arial, sans-serif]Front sun visors with vanity mirrors and lights[/FONT]
  • [FONT=Arial, sans-serif]Lights-on warning[/FONT]
  • [FONT=Arial, sans-serif]Car/Key Memory[/FONT]
  • [FONT=Arial, sans-serif]Cruise control, programmable[/FONT]
  • [FONT=Arial, sans-serif]Fogging sensor, front windscreen[/FONT]
  • [FONT=Arial, sans-serif]Oil temperature display[/FONT]
  • [FONT=Arial, sans-serif]Instrument panel with permanently white-illuminated displays for speedometer, rev counter, fuel and oil gauge[/FONT]
  • [FONT=Arial, sans-serif]Electric windows front and rear with anti-trap function[/FONT]
  • [FONT=Arial, sans-serif]Electric steering column adjustment[/FONT]
  • [FONT=Arial, sans-serif]Glove compartment, illuminated and lockable[/FONT]
[FONT=Arial, sans-serif]Audio & Communication[/FONT]
  • [FONT=Arial, sans-serif]BMW Professional radio with:[/FONT]
  • [FONT=Arial, sans-serif]Single disc CD player[/FONT]
  • [FONT=Arial, sans-serif]Aux-in connection for MP3 players[/FONT]
[FONT=Arial, sans-serif]Additional M Sport equipment[/FONT]
  • [FONT=Arial, sans-serif]Blue Shadow[/FONT][FONT=Arial, sans-serif] cloth / Alcantara upholstery[/FONT]
  • [FONT=Arial, sans-serif]Brushed Aluminium interior trim[/FONT]
  • [FONT=Arial, sans-serif]M designation door sill finishers[/FONT]
  • [FONT=Arial, sans-serif]High-Gloss Shadowline exterior trim[/FONT]
  • [FONT=Arial, sans-serif]Individual Anthracite headlining[/FONT]
  • [FONT=Arial, sans-serif]M Aerodynamic package[/FONT]
  • [FONT=Arial, sans-serif]M Sports suspension[/FONT]
  • [FONT=Arial, sans-serif]Sports seats[/FONT]
  • [FONT=Arial, sans-serif]Three-spoke M multi-function leather steering wheel with gearshift paddles[/FONT]
[WorldCarFans]
Ok I need a cold shower! What a sexy sportwagon. I wish Mazda would build a Mazdaspeed 6 Sportwagon.
You know, I love fast wagons more than anything, but the styling is just kinda blah on this one. It doesn't do it for me. I know its fast, but nothing about this car does it for me... its kinda sad.
Fast wagon no doubt but I've said it once and I'll say it again:
CHRIS BANGLE RUINED BMW DESIGNS!! FLAME SURFACING IS A CROCK!! MOST CURRENT GEN BMWS ARE UGLY!!!!!
Including this one. The only decent looking bimmer out now is the curren 335i coupe with the TTI6. Thats it. The rest of them look like mis-shapen monstrosities. I used to be such a HUGE BMW fan, as a matter of fact the last gen M5 was my fave car for the LONGEST time! BMW's used to have handsome understated styling that while not catchy was ALWAYS tastefull and well executed. Now.....UGH!
This is what a AUTOBAHN BURNIN BAD BOY wagon should look like:
RS4 Avant
400+ HP
AWD
0-60 in under 5 seconds
Handsome Good Looks
YES PLEASE!
dmitrik4 said:
finally...BMW puts a decent engine in a 3-series wagon. love it.
Decent engine by what means? this 3.0l has been in past wagons, this variant just happens to be twin turbo'd.
Also BMW doesnt use V6's and never have.
I won't bore you with another "what's going to be my next car" story this week, but right now I'm pretty sure it's an 2000-2002 323i/325i wagon (well, both have 2.5 liter motors). Then it's either an M3 or 3.0 liter swap in a few years. It's a b**** finding one in manual, but they can be had for 12K to 15K.
That way I'll have a killer sleeper mini-wagon with Bangle-less design. :D
I agree brother. Ugghh.
R
You're such a smarty pants. I meant to say inline six!
Still an ugly bimmer.
The psychology of design has indeed perplexed my inner thoughts. At times they are touched with a smile, whilst others are believed to be of disgust. Damn that Bangle character.
1st thing I would do after buying it would be to remove those gawd-awful roof rack bars... can we simply put that motor in my p5?
That is correct but they have not made alot of power here in the states. 00 323it and 01-05 325it only had around 190hp. BMW really should have marketed a 330i touring with the 225hp 3.0L. The 00 323it used the old M52 from the e36 and the 01-05 uses the M54 from the rest of the e46 line. The new 3.0L is the N52 which is a completely different motor from the old M52 and M54.
Rogue Engineering has done acouple of S54 3.2L swaps into e46 Tourings. I'm waiting to see if BMW does a e91 M3 Touring with the V8.
Or just wait for Hartge to put the S85 V10 from the M5 or M6 into a e91 touring.
Ahh the good old days when Bimmers still had decent styling. It's no Audi RS4 but it looks much better than the current wagon.
I was waiting for you to comment. Have you driven any of the newer BMWs? I can get over the styling because of the way they perform.
Nobody else read the part concerning the tow package? That alone is a pretty cool feature, if you have to tow a small racecar, like me....
