KN-1004 ? Does it fit ?
On the K&N site, the OEM replacement is the HP-1008.
This is the K&N filter you will need to replace the stock one.
<TABLE cellSpacing=2 width=744 border=0><TBODY><TR><TD width=283>
2002 MAZDA Protege5 2.0L L4 F/I - All</TD><TD width=90>
Automotive</TD><TD width=82>
Oil Filter</TD><TD width=82>
HP-1008
</TD><TD width=185 bgColor=white>
</TD></TR></TBODY></TABLE>
<TABLE id=table_spec style="HEIGHT: 39px" cellSpacing=1 cellPadding=1 width=400 border=0><TBODY><TR><TD bgColor=white>
HP-1008 Product Specifications</TD></TR><TR><TD bgColor=#ffffff>
Product Style: Oil Filters
Height: 2.91 in (74 mm)
Outside Diameter: 2.656 in (67 mm)
PSI Relief Valve: 11-17
Anti Drain Back Valve: Yes
Weight: 0.5 lb (0.2 kg)
Product Box Length: 3.15 in (80 mm)
Product Box Width: 3.15 in (80 mm)
Product Box Height: 2.91 in (74 mm)
HP-1004 Product Specifications</TD></TR><TR><TD bgColor=#ffffff>
Height: 3.48 in (88 mm)
Outside Diameter: 3.12 in (79 mm)
PSI Relief Valve: 11-14
Weight: 0.6 lb (0.3 kg)
Product Box Height: 3.48 in (88 mm)
I do not know if the HP-1004 will fit. Is the oil entry hole the same size ?
<!-- / message --><!-- sig -->
