LinuxRacr said:Have at it. There is a place reserved in the dumpster for this thread, so let's have a clean disscussion.
Fast lane said:so do you want to include stock injectors, along with running extra bigger injectors? or just 4stock or 4 bigger alone.?
Fast lane said:Use stock injectors while not in boost so you can keep good idle ,good startups, and better emissions,that matters to some people, like me, but once boost starts to hit you have the bigger extra injectors kick in so the car can meet its fuel needs with out causeing stumbles out of boost. This is what im running and its only been a week but i have no problems and the cars i have seen doing this have not had problems unless they had other problems to begin with. I mean if you think of it , it all makes sense no need for the bigger injectors while out of boost its like driveing na.
This is my opinion and im not putting down anyone elses set up.
TurfBurn said:All of the methods work plain and simple. Just each has it's pluses and minuses.
Fast lane said:Well i guess we will find out this summer which is best with all the proteges, going into the 400whp level. Cant wait!
CustomMSP said:I'm curious to know if any engine management can control the duration of the spray and the patter like the stock ECU? With the stock MSP ecu we can get enough fuel for more than 12psi on the T25 on the stock injectors. However they run out of breath at around 8psi with any other fuel management. I've read that the stock ECU changes the width and the duration of the injectors accordingly?
Thanks.
TurfBurn said:I. Poorer atomization can also result in greater cooling effect of the gasoline charge.
orangezoom said:I know when I put my emanage in, that the stock injectors where almost at 100% duty cycle, so I had to put in bigger injectors.
MPNick said:Is this the only good thing about bigger injectors not spraying right at idle? Not that I agree with this but how hot is the change air at idle anyway?
MPNick said:I do not how you ran out at the power you were at. Where are your dyno sheets now? I saw then a while back posted somewhere. Can you repost them please?
