- Protege5 2003
The P5 has 2 dead door lock actuators and one iffy one. I don't have time to fix them before the car goes off to live with my daughter, so I want to disable them. The goal: "old school" key only entry, with no evil spinning broken plastic noises and no doors in the wrong locked state when least expected.
In the manual it shows a 30A door lock fuse that powers the door lock control module, and that talks to the keyless control module which appears to be powered from both the Wiper and Room fuses. What should I unplug?
1. The 30A fuse.
2. The cable to the door lock control module
3. The cable from the keyless entry module
4. ?
I don't want to blow up either control module, or lead the keyless module to start honking the horn uncontrollably. (I have no idea if it even works, have never tried the remote.) At some point we might get around to fixing this, so it would be good to be able to plug it all back in and still have the electronics functioning.
Thanks.
1. The 30A fuse.
4. ?
Thanks.
