I have a random question about motor mounts. I have, after previously trying inserts and not liking even that amount of vibration, decided to replace my worn mounts with new stock mounts. However, when I got the mounts the rear mount appeared to be rotated. The rubber is rotated within the metal support so that once installed the weight of the engine is sitting on the solid rubber part, instead of hanging by that part. I guess you could say it is oriented vertically instead of horizontally. My question, or questions are: Is that some sort of weird intended change? What are your opinions on the extra stress put on the mount by being positioned that way? Has anyone ever tried rotating the rubber within the mount, do you think it could be accomplished without ruining the mount?
