Best jack spots for 2001 protege
I am wondering what are the safest jack spots to use on a 2001 Protege that has had both rocker panels replaced and is generally rusted along the floor panels and such. Where the cross members meet? I am looking to do several items over the next month (new struts, oil and trans fluid changes, new brake pads and rotors) and need to be as safe as possible. I got a good 2 ton low profile jack and stands with chocks.
Pictures of what to look for would be helpful!
Yeah, there are lots of good places. The front subframe on both sides where the lca's connect is good. The center of the rear subframe is good. Those are the ones I usually Use. I throw the jack stands under the pinches, but It sounds like you might not be able to do that. A good spot to place jack stands will fully depend on the specific design of your jack stands.
