Best Fuel Map to start?
03SLVRMSP
2003.5 Mazdaspeed Protege
well guys i am finally going to tune my car for MY first time sense i have owned her. seeing if anyone had advice on where, other than stock, might a good place to start? the car is tuned now but i have no idea with what map. my thinking was either start with the super map or start with a map that someone else has built that has close to the same mods as me. found one map that has just about the same mods with the exception of the 626 mani. figured start there and just take my time and trim it out little by little. i have all day tomorrow so i expect this to take some time. any advice is appreciated
i started with a map close to my setup and then just tuned from there, you should be fine doing that.
you could also go into your fuel maps and then read data from the ecu and then you could tune the map that you are currently running instead of starting from scratch
thanks guys. and rich i will take you up on that. i tried to tune this weekend but my comp would not connect to the controller and we think i bought a crappy cord and cant find a driver that works with windows 7 64 bit. we are going to try again in a few days with 32 bit and if not then when i get home i will for sure give you a call!
