Best Amp for 1000watts RMS for under no more than 380
nautical2086
1999 Mazda Protege ES
sup , the pics below are what blew on my amp, I am going to attempt to purchase relacements for the blown IC's that you see below, if that does not work, what do you guys suggest be the best amp for no more than 380 buxx and will produce close to 1000watts rms?
toasted amp. yummy. what impedance do you need 1k watt? you can get a tad over 800 watts into a 2 ohm load from a T3002 from RF that'll run you about $193. or you can get a tad over 1k watt into a 2 ohm load with the RF T5002 for just under $240. but if you want some more power, you can get the T10001BD for about $365 and it'll put out about 1.5k watts into 1 ohm.
course if you want to power your components as well, you can get the T8004 for just under $400 and i'll put out about 200x4 into a 4 ohm load. bridge the rear channels and you get the same power as the T3002 for powering a sub.
i'd go for the T10001BD. it'll put out around 950 watts into a 2 ohm load, but you'll have plenty of headroom and if you want to you can add a second sub and drop it down to 1 ohm and get about 1500 watts out of it.
I deff don't think im adding another sub, 1 Alpine Type X is already enough to make me loose my hearing, lol.
looks like i might end up with the Alpine MRD-M1005 after looking, spec to spec wise it looks perfect for the type x.
