Hey people, I was wondering. How do we identify when the rods are slightly bent? Except with the cylinder compression/leak test...how does the engine behaves? I mean:
Hows the power on low rpms?
Hows the power on high rpms?
EGTs?
A/F?
Vacuum readings?
Noise?
Smoke?
I noticed that when I first blew 2 of my pistons, the one that has the most damage is bent too. But the pistons where so damaged that the problem was obvious with all that smoke.
But if there is no broken piston...then there is no leak, no smoke at all!
(dunno)
EGTs?
A/F?
Vacuum readings?
Noise?
Smoke?
(dunno)
