I got several pics of you need some, or I can go take more. I just put them back on this past weekend after having them off for the summer.
As for fitment, they fit great. The front half is a little tricky to keep against the car, but if you're having a professional installing them, I wouldn't worry. My painter and installed mine and used little plastic clips to hold the skirts on. Then we used black plastic mesh to fill in the vent. As far as car height is concerned, they do sit somewhat lower than stock, and you'll have to be careful if your car is lowered. I'm using Eibach springs, and although I don't remember scraping the car on the ground, there were alot of scrapes in the paint on the bottom side of the side skirts. Basically, just drive carefully and you'll be aight! Lemme know if you want pics from certain angles. lata
