BC Racing Extreme drop coils
Im sure its on here somewhere, just cant find it after lots of searches. When I go to order my BC racing extreme drop pack, should i order shorter springs and higher rates such as 10k/6k if i plan on going low as possible, or will the standard spring lengths and rates be fine? Also what is a good source to go through to get these custom requests met?
Anyone know? just looking to see if 7/4 is fine or 9/6 or so would be a better springs. Also want to confirm part# N-03 is the extreme drop kit.
i'm not sure what the 'pack' includes, but you should get the coilovers because oem shocks/struts will not live long with any sort of 'extreme' drop.
and extreme drops will kill handling because you remove a ton of wheel travel.
