Battery drain due to ventilated seats (2019-2022 CX-5)
cz5gt
CX-5 GT
Anybody had any problems with battery draining because of the ventilates seats not turning off?
i.e car is off but the ventilated seats keep running. Usually after prolonged use of the ventilated seats function (i.e and hour or more in hot weather)
I haven't had this issue on my past 3 Mazdas with vented seats. I do daily trips where I run them for over an hour.
If they continue to run after the car is turned off, you clearly have an issue which needs attention at a dealer. Are you still under warranty?
Yep, definitely an issue, just wondering if more people have experienced it. Thanks.
My 2nd CX5 is under warranty so it should be covered..first doesnt have vented seats.
Just found Mazda has a new TSB.
Adding it here in case other folks start to experience this in the future.
Seems the vent seats computer is flawed and has to be replaced.
When my battery went to 6V it got me curious what is going on and started digging.
I have the 2nd cx5 for 8 months and never had issues but I also didnt use the ventilated seats much until recently.
Thankfully its a deep cycle AGM so it survived with a recharge after.
Did anyone notice if fan stays on after turning off car does the light stay on too so you can see its still on or do you have to listen for the fan? Thanks
Listen for the fan. btw Not all cars will have this defect.
Ventilated seats have to be used for extended time (hour or more) and in very hot weather. That was my case when it happened.
The problem is the seat warmer/ventilation control unit. Replacement is with new unit which is under passenger seat.
Thanks, this is Daughters car would just be easier for her to look at light to see if on instead of listening for fan. Reason I was asking as car hasn’t started two weekends in a row where it sat for 24 hours and battery was around 8-9 volts for no reason. Used charger to charge battery and started fine every day until second weekend and was just searching for reason. Load tested battery that was built Sept 2025 and it is not the problem. Will ask her to listen for fan when she turns off. Thanks!
buy a cheap clamp meter and measure Amps draw.
Open hood, close doors ... wait 15-20 mins and measure. should be very low...otherwise something is sucking battery dry :)
if its the seat unit, disconnect and measure again. Its easy. it can also be left disconnected if that is the problem but could be other things.What year is the CX5?
2019. Thanks will look for meter
Before you buy, make sure it's sensitive enough to read down to mA (milliamps), otherwise you'll be reading zero when it's not.
And actually, if it's a clamp meter we're talking about, it will never read zero. The background noise level will overwhelm. That's why small currents can't be accurately measured with a clamp.
But here's the best bang for the buck (IMO). I paid $70 in 2022 so it has crept up a bit, but it's still a substantial savings over some other brands.
And actually, if it's a clamp meter we're talking about, it will never read zero. The background noise level will overwhelm. That's why small currents can't be accurately measured with them.
They show a "Used- Like New" unit available for $70 so you still get a deal....
get some cheap amazon one (30-40 usd) with good reviews that can measure as low as 20 milliamps. No need for paying big bucks for one time test. My honest opinion.
and make sure to test at least 15 mins after all doors closed and lock the car if you want. just keep hood open. Dont remember if Canada CX5 has hood sensor (US models dont) but if there is any you can just keep it pushed manually.
I disagree. If you're trying to measure currents that low, you can't do it with a clamp meter using the hall effect. Measurements that small need to be done using the probes, which means testing fuses.
you can disaggree for sure but my amazon device disagrees with you on the target/goal here. It can measure it and at least confirm if there is issue or not with some electric consumption when car is shutdown.
We are talking general DIY stuff not professional grade services.
you can disagree for sure but my amazon device disagrees with you on the target/goal here. It can measure it and at least confirm if there is issue or not with some electric consumption when car is shutdown.
The problem is that a hall effect meter will not ever read zero due to background noise. There is always a fluctuating reading and if what you are trying to measure is anywhere near that range, the signal is lost in the noise.
I had to go through this hunting down a parasitic drain already. The clamp can tell you power is flowing but at low readings is useless. The only way to get accurate low-level readings was using the probes.
Here is how you connect them to measure power draw from the battery. Negative cable disconnected and clamped to the red probe, black probe connected directly to the battery's negative. The battery's positive cable remains in place on the battery.
You can use a cheap but excellent https://www.amazon.com (commissions earned) for this. Set it to DC amps and make sure to not exceed the rating on the meter or you will blow it. I would not touch the start button at all as you'll surely exceed 10A instantly with the headlights, fuel pump, etc.
I also got this cool https://www.amazon.com (commissions earned) for it which seems is hard to get now.
Video on how this works:
However: I don't like pulling fuses. That can wake up the car, so it's better to test them directly using the probes.
Testing fuses directly:
Fun stuff.
