Batlock Battery Connectors
I've got a bunch of different battery terminal connectors. They fit an array of battery terminals, and they're a great quick way to connect your battery cables to your battery. I'll list the information for each one below as per package states. I'm not looking to sell them for a bunch of money, I just need to get them out of my apartment and clean my closets of boxes of stuff out. Prices will include shipping to any of the 48 continental states and will be the same for each product regardless of which one. If you need more than one I can combine shipping, however if they require a larger box to ship in, I will ask that you pay the shipping difference (should not be more than a few dollars)
All packages contain *2* connectors, one for the POSITIVE cable, and one for the NEGATIVE cable
All of the connectors offer:
* Vibration resistant
* Quick connect/disconnect
* Tighter connection
* Corrosion resistant
* Handles swivel and rotate to almost any position
Heavy Conversion Kit - Quantity (3)
* Quick handle release for easier installation and removal
* Handle swivels and rotates - almost any position
* Hook and loop system - designed for breaking up corrosion and easy release from top post
* Tightest connection system offered
Designed for top post terminal, 1/0-2/0 gauge wire recommended
L - Post - Quantity (9)
Designed for L post terminal
Conversion Kit - Quantity (7)
Designed to replace the nut/bolt that is already on your terminal
Designed for top post terminal, 4-6 gauge wire recommended
Side Post - Quantity ( 10 )
Designed for side post terminal
Price for each one shipped will be $15 and can be made via paypal to redcats4@hotmail.com
Shipping will be done via USPS Priority mail, which means you'll get your goodies within 2-3 days on average! I will ship out normally within 1 day after payment has been made. Any questions feel free to ask. Thanks :)
Side post, L post, and the conversion kits. I do not have any of the top post terminals left. The conversion kits will work great on your current top post terminal after you remove your bolt/nut and replace it with the kit. It will make your terminal a quick connect/disconnect
