So guys, I'm the new pig, got me a 50 shot nitrous kit with purge, care to let me knwo where to get a fuel cut off for the p5 in case of the stock pump starts leaning out?
Also more info on exactly when you spray, assuming it sprays when yer WOT, you just shift into second, flip the WOT activate switch, and floor it, shift to third, floor it, shift, floor eh? lol
I'm running clutch, flywheel, header, 2.5" catless exhaust, cold air intake, and most importantly when your car has more than 20hp over stock, Motor mounts! Any suggestions you guys have? plan on running 50 shot, may renozzle it to 35 tho
also, any update on the colder spark splugs I should get? I'm running platinums and need to change em
Congradulations on the new Nitrous Kit...What type of kit was it? I didn't see..
I love my purge..I got it runnin over the winshield now...
You REally don't have to worry about stock pump giving out...but it is usefull to have fuel pressure cut off switch..I have one!!
I spray in every gear...But not to much in 1st & 5th...
1st gear causes my tires to spinnnnnnnnn like crazy...but i shoot in 2nd through a little of 5th..but by 5th gear..i already know who won!!
What do you mean you are runnin clutch? You mean aftermarket? If so that's good but not necessary..I have had my stock clutch w/ really no problems shooting unless i am shooting in 1st gear...
I got a motor mount (kart boy)..it's pretty good..but i am still gettin some wheel hop..
About the plugs...NEVER USE PLATINUM PLUGS...they will explode..or foul up really easy..and has lead to damaged engines..that's why it specifically says in any manual..or install book...NEVER US PLATINUM PLUGS!
I am running 1 step colder plugs...i have the mp3 ecu..so i have the advanced timing...and always fill up on 93...but sometimes..94octane..but gas cost so much now...
Good luck and keep us up to date..i like to know how other protege's are kick ass using nitrous!!
Im running a NX 50 shot and even when using the nitrous the motor runs extremely rich, all the way green on my guage!! You shouldnt have anything to worry about with the motor leaning out. Ive been through alot of nitrous and had no problems or noises.
Yeap..the p5 runs really rich...I have an a/f meter and whenever i shoot it reads all the way into the green...
Im timing my p5 tonight if it stops raining, hoping to hit high 15s. I wish i lived wherever u live, whoever hit the 16.4 on a stock motor, here in kansas I can only manage a low 17 on stock motor (bc of crap air).
It started rainin like crazy here in Jersey...I hit the 16.4 mark...was little difficult..but practice makes perfect!! Got to know how to drop it and not to bog down the car...not to mention..i have a custom ram air kit...Really kicks ass when i am on the highways...
I figure w/ a 50shot stock p5..you should easily be into the 15's...but you need to practice...
w/ a 75shot...you in the 14's...
I figure w/ my setup..I should easily be in the 15's..but i am shooting for 14's...(high of course)..
Chas
P.S. Glad to see we are getting a better flow of people goin the nitrous route!!
