This has happened a couple of times the last few months.
When starting the car this morning, I got an indication that rear door is open, I close it properly, but after 1km the indicator says the door is open again. I stopped the car and could see the door is not properly locked, I close it again and drive for 20 km, then the same thing happen again.
Is this a common issue, or is it possible to make an easy adjustment? Car is still under warranty, so I assume this would be a warranty issue.
Brgds
Svein
Brgds
Svein
