Axela emblem here
How do you put the rear mazda emblem on.....i know you have to glue it in ...but how do you get the trunk plastic off??/
thanks for help
Do NOT use glue! Use 3m double sided tape. No need to remove the inside plastic Hatch cover. Dental floss works really good.
thanks for help
I took a bunch of my emblems off and it was extremely easy. Just take fishing line, about 8-10lb test and a haird dryer. Blow the hot air on the emblem for about 1 minute and then slowly work the dental floss across the emblem. Do not pull it through, rather go back and forth and it will slowly come off. Make sure you watch out for the plastic pins that hold some in place. Then just take some water and 3M adhesive remover to take the residue off, then stick it back on with double sided car tape that 3M sells. I've had mine changed for about 6 months and they are stuck on there better than when i got them from the factory. Good luck.
