jdub260 said:
What's the difference between these two mounts?....besides $70!!
cp-e
AWR
I don't even know for sure if they are for the same location but I would like to know which one is better/stronger or any other info that anybody has.
Thanks in advance.
Ive installed the awr mount. However i had problems installing it. The awr mount is flat on both ends of the bushing. Its not a problem on the engine side however on the bodyside the original mount sits in a cradle. For me, i was not able to get it in. I had to hack away some of the urethane to get it to fit. Perhaps some other people are able to.
If you look at the cpe one it is not flat and sort of "volcanoes" out to sit/fit in the cradle.
This of course is just my experience with it. I dont have access to a lift, just used jack stands. Perhaps i didnt have enough leverage. I was too tired by then fighting with it. Even when i did force it in, since it prys open the bodyside, the bolt would not go in (could only get one side in cuz couldnt align it)
So i said screw it and had to hack/cut the urethane to finally get it in.
So im not giving the product a bad rating. perhaps it was just me. So be warned.
Will give an update on how the drive/vibration is after a few days...
Oh ya, they are both for the same location. Some say that the urethane cant handle the heat, but its nowhere near the downpipe. And i cant see that kind of heat being transferred to it from the engine...
And the awr one is supposed to be stiffer than cpe. Negative may be too much shakin goin on for some.
