awr enlinks help
bamflee84
Hello, as most know the awr sway bars come with the adjustable endlinks. On the adjustable endlinks there are two rubber o rings on each side of the ball bearing. I wanted to know where else I might find these O rings besides getting them from awr racing in cali. Awr sells the rings for 50 cent a piece * 8 + shipping to NJ from Cali, just doesn't pay out, the guy there even told me so. But i can't seem to find them becuase they are oversized and not standard.
(1" outer diameter / 1/2" inner diameter / 1/4" thick ). Any help would be appreciated thanks.
hmmm. To be honest I have no clue, but you might wanna go look at Advanced Auto Parts store. They might have something.
They're just standard "O-Rings". Bring one with you to your local Lowe's or Home Depot and ask an employee. They'll probably find you some in the plumbing department.
BTW, you don't need to run the o-rings. The only reason they are their is to keep the links (also known as rod ends) from flopping around and making a slight clicking noise. I'm not using any on one end (can't remember which end...sorry). Just put enough o-rings on so that the links don't bind, but also can't rotate enough to touch metal to metal. If you look closely at them you'll see what I mean.
AWR makes really good stuff.
