clever_name
Fraimr8 said:Last i want to make sure i got the mod right. I move the yellow and black(mute)wire from its location to the empty slot directly above it on the radio plug then ground the yellow/blk(mute) and light green(parking brake) wires maybe to the stock ground wire on the harness(radio will be directly to chassie) so this means the yellow/blk wire really has nothing to do with the mute circuit anyways because its actually hitting a different pin on the radio?
well thanks for hearing me out any input will be greatly apreciated.
Yes, that is the correct mod, worked perfect for me. I just grounded the parking brake (light green) and the mute (yellow & black), after moving it up one pin, to the same spot. Haven't had a problem yet!
