Ok AutoXers...i'm looking for some advice.
i'm trying to decide whether to stay H Stock or move to STS. there is pretty much no one in H Stock in Philly, but STS is CRAZY competitive. my times from last weekend would have put me 9 out of 16 in STS, and i'm running a totally stock Protege. ok.
from reading the rules, it looks like i can change the springs/struts and stay in HS (or go to STS if i want). if i stay in HS, i would probably spend my (limited) money on suspension mods and keep my stock wheels/tires.
if i decide to move to STS, i will most likely spend $$ on 15" used rims and Azenis (probably 205/50R15), which are actually slightly shorter/wider than stock and would give me a slight gearing/traction advantage. i would also probably go w/ the 21.5mm rear sway bar and front strut tower bar. i say the 15s b/c i bought a set of '88 RX-7 rims (15x6.5") that would handle the Falkens perfectly and weigh even less than the stock Pro rims (which turn out to be pretty light).
also, as far as suspension mods...IIRC, the MP3 springs fit the ES but the struts don't. Are there comparable struts that DO fit?
